Use Software Record Dumps
Capture a dump of the software records from ingress traffic to help troubleshoot performance problems. Generally, a verbosity level of 1 suffices.
Switch:1> enable
Switch:1# dump ar 1 vlan 1
The following table defines parameters for the dump ar command.
| Variable | Value |
| <1> | Specifies the slot number. |
| WORD<1-1536> | Specifies a record type in the AR table. Options include vlan, ip_subnet, mac_vlan, mac, arp, ip, ipmc, protocol, all. |
| <0-3> | Specifies the verbosity from 0–3. Higher numbers specify more verbosity. |
